주요 콘텐츠로 건너뛰기
Netbooks도 수리가 필요합니다, 자사의 안내서를 사용하여 계속 사용할 수 있도록 하십시오.
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 14
댓글 1개
Where can I buy a screen for it
댓글 달기
답변 5개
가장 유용한 답변
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
댓글 달기
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yes how much it cost to replace it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
How to fix the part were the charger goes into the nextbook
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alexander 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 5,930
