주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wii U는 Nintendo에서 만든 휴대용 기기와 연결된 게임기로, 사용자가 GamePad로 게임을 즐길 수 있습니다. 이 기기는 매우 모듈식으로 설계되어 있어 수리가 간편합니다.
Replacement ribbon cable clamp?
So today I decided to replace my gamepad screen, since my old one had a scratch that make a area of the screen untouchable. Seems while in the process one of the ribbon clamps came off.
here it is.
I found it, but while trying to put it back on it snapped in half. it looks like this one.
Here.
Anyone know if (and where) I can find a replacement, or a way to make it work? Everything works fine except for touch, which is what this cable is for. I hear electrical tape can work, but I don't know what exactly to do with that.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 5개
선택된 해법
Position the ribbon cable onto the conector and then use white tak...its like blue tak but kind of sets harder!...to keep the cable pressed down.
This worked for my one!
You might have to try a couple of times before you get it to work!
Take a look at my YouTube video...
https://m.youtube.com/watch?v=mNbxeLlpaO...
http://www.amazon.co.uk/WHITE-TACK-BLUE-...
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
Would love to see this youtube video. I just tried and got nothing :/ Is the ribbon supposed to lay on top of the connector, or under? It slips in under so i figured thats the right way to do it.
Just doing my vid today... i'll post on YouTube tomorrow and I posted the link asap.
Awesome, thanks!
great solution, thanks!
댓글 달기
가장 유용한 답변
The ribbon cable socket is desoldered from the logic board. It can be soldered in place but this have to be done by a pro. Find a place that repair iPhones and ask them to do the job.
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
Isn't the socket what the ribbon cable goes into? I'm just talking about the gray thing that clamps down on it, unless that's what you're talking about.
OK, doublechecking at the first pict I think that it's the cable that need to be replaced. The connector is desoldered from the cable and seat now in the socket. Not sure that the connector can be soldered to the cable.
Looks more like the grey clasp is broken off. It provides downward pressure on the cable and allows it to make contact.
oldturkey, is it the same type of socket than the keyboard backlight socket on a MBP ? You insert the cable in it and push down a lever to secure the cable ?
The cable's fine, the angle just makes it look weird. I am talking about the gray part that clamps down for pressure.
댓글 3개 더보기
댓글 달기
I need this answer too. Chrisall76 did you ever get something to work?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Nope, had to buy a new gamepad.
댓글 달기
Does electrical tape work?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i taped it with gorilla tape... but when i had to replace the touch screen the tape didnt work anymore.... im trying hot glue next
댓글 달기
i did the same to the clasp that is for video....the one in your second pic. i put tape on it....keeps going off. i started to put hard things on top of the ribbon with tape for pressure and still comes off. some said glue but i dont like that idea because one it can cover the pins and two what if you need to replace stuff and it cant come out. i was wondering if the clasp was replaceable too
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Fixed this whith white tak...
댓글 달기
답변을 추가하세요
chrisall76 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 39
전체 시간: 12,298
