주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
7인치 스크린을 탑재한 향상된 성능의 2세대 Google 브랜드 태블릿입니다.
How can I replace the microphone?
Hello, I bought a refurbished nexus 7 2nd generation tablet, and the microphone doesn't seems to work. Anyone in a video or audio chat only hear faint popping sounds.
I was looking to replace the microphone if that's possible. Does anyone have any tips or instructions on how to do this? I can't seem to find anything online regarding this topic for the 2nd gen nexus 7. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
i have this problem too)
의
댓글 달기
답변 2개
가장 유용한 답변
Nexus 7 (2013) microphone replacement -
For anyone who might have stumbled upon this while looking for a solution to this problem - the microphone is an integral part of the power/volume button cable assembly (black 4x5mm rectangle on the end).
이미지
Once the device is opened up (which may or may not be easy and may have contributed to damaging the mic in the first place), replacement of that full cable assembly (typically <$10) is very simple. No soldering required. It is held in place by adhesive and electrically connected via a latchable ZIF socket that the small ribbon cable end slips into.
My mic was fine before I replaced the screen, but unusably weak afterwards - only functional by shouting directly into it. Replacement of the cable assembly as described here fixed the problem.
Fix unresponsive volume and power buttons by replacing the internal button switches and their flex cable. This part is compatible with a 2nd generation 2013 Wi-Fi model Google Nexus 7. 이미지
제품
Nexus 7 (2nd Gen Wi-Fi) Volume and Power Cable
$29.99
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Helpful to know it's easy to replace. I use the mic only quite rarely. Unclamp the socket first!
Thanks!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
charlescantoni 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 1,769
