주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE Boost MAX N9520은 5.7형 HD IPS 디스플레이, 4G LTE 및 Android 4.1을 탑재하고 있습니다.
screen touch does not work after replacement?
I replaced the screen and digitizer and the screen comes on but touch doesn't work. I've checked all connections twice. What could it be?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Jeyson......did you end up fixing this problem??
의
I have the same issue. My ZTE zmax pro z981 screen broke and I bought 2 new screens and after I put new screen it lights up but doesnt respond to any commands
의
I have the same problem except mine's a ZTE n9521 screen not responding to touch
의
댓글 달기
답변 1개
선택된 해법
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jeyson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 17
전체 시간: 1,616
