주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
7인치 스크린을 탑재한 향상된 성능의 2세대 Google 브랜드 태블릿입니다.
Why won't my computer recognize my device?
When I plug my tablet into my computer with the USB cable, my computer doesn't seem to recognize the device. What are possible causes for this and how can I solve it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
The problem you are having could be due to a number of reasons such as a faulty USB port, cable, or Micro USB board or un-updated software. Please visit the Nexus 7 (2nd gen) troubleshooting page for possible solutions to your problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Here is what worked for me; After I initially my tablet to my computer it worked fine until my computer updated. I tried everything except removing updates because I had no idea which was the problem. What worked was; with my tablet connected to my computer by USB cable, open my Control Panel, open the Device Manager, find my tablet in Portable Devices(in my case EGQ307) and right click on the device. It gave several choices, most of which hadn't worked before, so I tried the only one left uninstall. I then followed correct procedures for turning off and disconnecting my tablet. When I reconnected my tablet my computer immediately found and loaded the driver and my tablet worked with no problems. I still don't why it does this (it has happened twice) but at least this fix works.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Are you a new Android user? If so, this will be an easy fix. After you connect the tablet to a computer a notification from the top will appear and ask if you want to trust the computer. Just tap accept.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i installed drivers so computer recognizes nexus 7. i read that previous drivers need to be uninstalled before installing again then nexus root toolkit should work perfectly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jillian Brown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 5,408
