주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
게임 및 음성 오디오 균형을 조절할 수 있는 탈착식 마이크와 선택 사양인 Mixamp Pro가 포함된 비디오 게임용 헤드셋입니다. Xbox 1, Xbox 360, Playstation 4, Playstation 3 및 PC와 호환됩니다. "Gen 2" A40 헤드셋은 2014년에서 2015년 사이에 출시되었습니다.
Do sounds seem reversed while using the headset?
When sound sources that should be coming from the left or right come from the opposite side of your headset.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I have the same problem someone please help asap.
댓글 달기
답변 3개
선택된 해법
Hi Sam,
You may have a 'reversed' connection in either the headset cable or the headset itself.
If you have an Ohmmeter you can test this out. Test from the 'tip' of the cable plug at one end to the 'tip' of the cable plug at the other. There should be continuity. By convention the 'tip' is the left speaker.
The next connection on the plug down from the tip is known as the 'ring' and it is used for the right speaker.
If you get a connection from the tip at one end to the ring at the other your cable is reversed.
If your cable tests OK it may be that the wires in the headset itself are reversed.
Either way I suggest that you contact the manufacturer as obviously it is a production fault, as I assume that the headset cannot be worn or altered to suit.
The image shows typical connections. Usually it is only the microphone connection that may vary, unless the manufacturer wishes to have a 'proprietary' connection setup which forces you to purchase their product, (until you work out the connections yourself , of course).
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
its basically pretty easy. i had this problem but i solved it in few seconds.
basically you have the magnetic cover of the astro headset. First you need to remove ur microphone then u need to switch the outside magnetic cover ( the one with the microphone hole in it. Just switch those over and ur good to go. ull notice that the astro has 2 microphone hole on both sides. and voila problem solved. Hope I could help !! cheers
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Is there a video that shows you how to do it?
It was exactly the problem. Awesome. Thank you
댓글 달기
Make sure your headset is on correctly. Your left ear should be listening to the speaker labeled with 'L'.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have the same issue please help!
댓글 달기
답변을 추가하세요
Mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 35
전체 시간: 22,756
