주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Air Raid는 2013년 11월 15일에 출시된 무선 휴대용 블루투스 스피커로, 블루투스가 지원되는 모든 기기에서 음악을 스트리밍할 수 있습니다.
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
의
Where do i purchase a new battery?
의
댓글 달기
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sasha Nevin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 5,380
