주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
Bootlooping because of power button
There's a common issue with N5 where the power button causes the phone to bootloop. I've stripped it down, but I'm unsure what to do with regards to fixing this issue. I've been quoted £30 to fix the power button, but I'm not sure if this will fix the issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 달기
답변 3개
가장 유용한 답변
The problem is with the physical button on the motherboard, which is just not so well designed, because dirt can get stuck into it.
Remove the motherboard from the unit, and blast some rubbing alcohol into the actual button part with an air duster. Wait until the board is entirely dry and reassemble. I have to do this every couple of months, it's a bit of a drag.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I temporarily fixed mine by button bashing the power button until the phone rebooted. I felt pretty stupid doing so but after about 20 seconds of really fast clicking on it quite hard it worked. I already tried replacing the battery twice since boot loops are often caused by power issues but without result. Anyone know a solid fix? Is it the button on the logic board that has to be resoldered?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have the very same problem. I really don't know what to do.
의 공유
댓글 달기
Saskia's answer above is the best solution short of replacing the part (i.e., replacing the motherboard, in most cases probably more hassle/expense than it is worth).
One quick and dirty, no-disassembly trick that worked for me several times was to rap the phone (in a bumper case) sharply against the edge of a counter with the power button facing down). Optional followup: with the button still facing down use the crevice tool (with the case off) in hopes it would catch anything that had worked lose in the thin gap between the switch and the phone body.
Not ideal but handy if you are on the road and want to give it a try.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Liam Cooper 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 35
전체 시간: 3,924
