주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년에 Canon에서 출시한 콤팩트 카메라입니다.
Why am I getting a Lens Error?
When I turn the camera on, the lens stays extended and the LCD screen displays "Lens Error/Will shut down automatically/Restart now." I've tried turning the camera off and on again but the error still displays. When the camera is off, the lens remains extended.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
See more suggestions below - lens assembly replacement almost always works.
의
Sometimes, the lens mechanism can get stuck or misaligned. With the camera turned off, try gently tapping or shaking it (not too forcefully) to see if it helps free up any obstruction or realign the lens. Be careful not to apply excessive force or impact that could further damage the camera.
의
댓글 달기
답변 5개
선택된 해법
This is a known error with the Canon PowerShot S100 camera. For more information, you can visit Canon's press release here or you can attempt to fix it here.
Here is a link to our troubleshooting section about this issue.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Replacing the lens assembly will almost always fix this error if simpler fixes don't succeed. See my guide for the process here: Canon PowerShot S100 Lens Assembly Replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Canon will not fix my camera because of rust and corrosion. I am warning people not to send their camera back. They are trying to get out of actually fixing the situation by forcing an out of warranty repair. I barely used this camera so I know that the rust and corrosion is not something I caused.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If Canon won't fix it, go with this place. They have serviced multiple cameras for me and they are excellent (about half the price of Canon).
This is who I used: www.camerasandparts.com
Good luck with the problem
의
댓글 달기
remove the battery. close the terminal. hold the on/off button for 1 minute. replace battery. turn on and use.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
your solution doesnt work
의
댓글 달기
I fixed my Canon PowerShot S110 with the vacuum cleaner. I turned on the vacuum, placed the hose over the lens, turned the camera on and off and hooray . . . it worked! Good luck fixing yours. Kathie
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricky 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 15
지난 30일: 107
전체 시간: 35,998
