Why does the engine warning light remain on
The engine warning light remains on.
좋은 질문입니까?
The engine light is telling you theres something wrong with your car and that you need to give it some attention . You can start by getting a OBDll reader and getting the code to tell you just what you need to fix. Once you have the code and have fixed the problem you can delete the code and the light will be out
이 답변이 도움이 되었나요?
You do not give us a lot to go on. I suggest that you get the OBD scanned at places like Autozone or others and see what code it returns. there are hundreds of reasons why the light could be on.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 21
전체 시간: 886
댓글 1개
it's the egr valve most likely. common ford problem
fath3rjozy 의
