주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2008년 3월 802.11n 와이파이(Wi-Fi) 지원과 함께 업데이트된 AirPort Express A1264는 작고 휴대하기 편리한 무선 네트워크 기기입니다.
Fix for AirPort Express A1264
Hello,
I have an airport Express a1264, it sometimes gives me a few seconds a green light, and then a orange one. I think then it's booting. But after 5 seconds it stops. When I try it again, then it isnt showing me any sign of life. Maybe it's the power supply. Please help me.
Kind regards
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
First give this a try: Resetting an AirPort base station FAQ.
You may need to reconfigure the AirPort. Download the AirPort Utility from here: Support downloads
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Hello,
I've done it several times, but the airport is not showing me a light.
I really think it's a hardware failure.
의
Can you access it via the Ethernet connection with your Mac running the AirPort utility?
의
I'm sorry for my late answer. But no, nothing works, it doesn't show up.
의
Ouch! Thats not good ;-{ Sounds like its time for a new unit.
의
댓글 달기
Based on your comments on the status LED, most likely, the power supply in the base station has failed.
Ref: AirPort base stations: About AirPort base station status lights (LED)
One possible means to try to revive it would be to perform a "factory default" reset on the base station. You may need to try this a few times. If this fails to solve the issue, you will need to replace your base station.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Diederik De Coninck 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 2,946
