주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
15.6인치, Intel HD 그래픽, Core i3 2330M, Windows 7 Home Premium 64비트, 4GB RAM, 500GB HDD
Laptop not turning on
I got a problem with my battery, it was not charging but i could use my laptop by using my charger.
But now, my laptop is not turning on at all.
when i press the swith on/off button, it lights on and my AC too
After a few seconds, it stops.
And also, when i press the on/off button, my screen stays off.
plz help me with this, am not so experienced in computer and am not been able to work.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Hi my Dell it was working fine day and night but one night I had run defamatory to optimise but the next day it does not on help me ###
댓글 달기
답변 1개
Hi,
I work for Dell's Social Media Team and would like to you help with your question.
Remove the battery and unplug the system. Hold the power button for 30 seconds and reseat (remove and reinstall) all memory modules.
Verify that the LED on the AC adapter is ON before you plug in the system board. If it is not, the adapter is bad, replace it.
If the system will then power up with no battery, but won't with the battery installed, the battery is bad.
If it won't power up at all, chances are the mainboard - or the DC power board if the system has a separate one - is faulty.
Hope this helps!!! Write back in case if you have any questions Thanks,
Pradeep,
Social Media and Community Professional
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
aksheyfouterdesord 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 1,155
