주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-84 Plus Silver Edition은 2004년에 출시된 그래픽 계산기입니다. USB 포트, 사전 로드된 소프트웨어, 앱(APPS), 저장 공간을 갖추고 있으며 앞면과 뒷면 케이스를 분리할 수 있습니다.
Flashing cursor on TI-84 Plus?
I haven't used my calculator since the AP Calc test, so I don't know specifically when it happened, but now when I turn it on, I can't do anything.
At first the screen just flashed "Ans^-1" (but the actual display of power of negative one) over and over, like I had selected it, but no matter what button I hit, nothing happened. I pulled out the batteries a couple times, waited half an hour, but nothing changed.
Then today I took out the backup battery as well, which did a little. Now it just flashes over an empty space, like when it's waiting for you to type the first number, but I still can't do anything with it. Help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Although this sounds like a hardware failure, you can try a software fix first.
Try to reinstall the OS. I don’t know if it’ll work for you since your keys aren’t functioning but you may as well try it anyways here. (Fun fact: the [on] key works because it’s hooked up to the calculator differently from all the other keys)
In the likely event that doesn’t work, refer to this guide for troubleshooting and hardware fixes.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
EJ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 32
전체 시간: 4,024
