주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1997년부터 2006년까지 생산된 Wrangler TJ 시리즈입니다.
replace rear axle seal
remove right rear wheel axle
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
bob petrik,
Jack up Jeep, support with jack stands, remove rear wheels and brake drums
Remove diff cover
Remove cross shaft retaining bolt
Remove cross shaft
Push axle shafts in and remove C-clips from inner end
Gently slide axle shafts out of housing
Remove seals, being careful not to knock the rollers out of the bearings
Install new seals
Great information from here.
Here is a decent video about the procedure.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Awesome information. I am new to all of this.... if I have a leaking seal, is there any reason that I couldn’t replace that without replacing the bearing?
의
The seal is separate from the bearing. There is no need to replace the bearing if it is still in good condition.
의
댓글 달기
답변을 추가하세요
bob petrik 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 10,348
