주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
What does the f22 error code mean
I ran a load last night and woke up to a F22 error code flashing. I am going to re-start the load. Is this something that will need follow-up?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 7개
Hi Diana, I know this is a very long time ago, but could you let us know if replacing door lock, part number 8183270, as @oldturkey suggested, fixed it?
I have this same issue, I ordered and replaced the Door Latch still getting the Error Code F22
@motleytom a year later, did you end up fixing it? If so, what did you need to do?
Is this the same on hotpoint condenser dryer it starts for a bit then F22 appears
Hi @Laura Evans,
What is the model number of the dryer.
Looking online most Hotpoint dryer error codes only go up as far as F17.
Is the error code being displayed as "F22" in a display window or is it being displayed as LED lights that have to be interpreted as to the code?
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
Diana Timmons, the F22 is a door lock failure. It will only occur after the control has tried to lock the door 6 times. The most likely cause of this problem is the door lock assembly is bad. You can try to hold the door shut a little tighter. If the door is not shut all the way or is crooked then the door might not latch. The door latch assembly is the most likely part to cause this problem and I would recommend replacing it. Get the service manual for your washer from the bottom of this page. The door lock is part number 8183270
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hey Diana, the f22 error for this washing machine usually occurs when the door isn't properly shut. Please make sure that the door is shut all the way. Also, if the problem persists then I'd recommend that you replace the door. You can get it replaced through warranty or manually.
-Let me know if this helps
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
There's no adjustment on these doors and I shut it properly. My problem is that it won't unlock, it locks fine.
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 116
전체 시간: 33,365
