주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 다목적 Android 태블릿은 2013년 5월에 출시되었습니다. 7인치 800x480 LCD 화면, 듀얼 코어 프로세서가 탑재되어 있으며 최대 32GB의 추가 메모리를 지원합니다.
How do I reset the unit
my unit comes on but wont do anything I am trying to reset the unit. how do I do that
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
My tablet is stuck on the trio stealth gs screen and won't boot up how can I fix it
의 공유
댓글 달기
답변 6개
가장 유용한 답변
Easy fix!!! re-install firmware - unzip and put on empty sd card - firmware found here - https://mega.nz/#!RNBmjBrI!hSmMhkf8acjjE... , put sd card in tablet that is powered off, hold vol + and power , android popped up and loaded files - flashed in about a minute , trio stealth g2 hype fully restored, working normally again, hope this helps anyone!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Mine would not do anything, no reset button, no android wipe menu, nothing, this worked in a "flash" :)
의 공유
댓글 달기
k festa, try this, but be aware you may/will lose your data:
Make sure tablet is powered off.
Hold down Volume + button and Power button at same time.
When screen comes on let go of Power button.
When the large Android shows on screen let go of Volume + button.
Use Volume – button to scroll to Wipe Data/ Factory Reset
Tap Power button to select.
Use Volume – button to scroll to Yes.
Tap Power button to select Reboot System Now.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
What can I do to get it to go further on through @9 dual core because I have been trying everything that I can think of
의 공유
The large android logo won't come up the device keeps turning on and off! any advice would be very appreciated
의 공유
@Sa Nassee what device and what have you tried?
의 공유
댓글 달기
Try this (I to had reset my WI-FI this way because it would not turn on)
1. POWER DOWN the device.
2. PRESS and HOLD the RESET and the ON/OFF keys until the device powers up.
(Your RESET should be a SMALL HOLE, usually NEAR the POWER, but make sure that you ARE NOT pushing on your MIC. That might damage your device. If you're not sure where the reset is, remove the back cover and check what is by the hole you are considering. It should be a small switch if it is the RESET SWITCH.)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi my name is Victor and I just tried to applied the reset and my tablet doesnt want turnt on ,do you have a some fix,Thanks
Best regards
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The following procedure is a permanent solution to your problem. I have found it to work quite well.
1. Power down device using on/off button on side of unit.
2. With device now off, turn it over and on the back upper corner is a small hole labeled "reset"
3. Using a toothpick or other small poking tool, press reset to button twice while also pressing & holding down the volume up (+) key and the large "home screen " button on the front bottom center of tablet.
4. When nothing happens, stop pressing all previous buttons.
5. While holding device firmly in hand, begin shouting obscenities as you forcefully throw tablet on to a concrete driveway or sidewalk of some kind.
6. If unit fails to break into several pieces, begin stomping on it with your feet until visual permanent damage is obtained. **WARNING: Backup any data you wish to keep before beginning step 6. This step will permanently wipe all data from this device.
7. Finally, go buy yourself a new, more expensive, better quality tablet & quit buying these sub-standard 'knockoff' brands that are nothing but P.O.S.'s.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hola he bajado el archivo pero me dice instalacion aborted. que hago?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
k festa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 28
전체 시간: 7,459
