주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1999년부터 2004년까지 생산된 2세대 북미형 Honda Odyssey에 대한 수리 안내서 및 정보입니다.
My code for my 04 honda
I need a code for my radio Honda odyssey
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 7개
You can get a honda odyssey radio code here; https://radiocodevault.com/honda
의
RIP OFF. Why should I have to pay for a code from my own radio?
의
Well, its better than the $70 the dealership charges... I used that radiocodevault.com site and it worked great :) It's like $15. No brainer.
의
did you read the answer by @oldturkey03 above
의
댓글 2개 더보기
댓글 달기
답변 5개
가장 유용한 답변
I got a working radio code for my Honda from https://radiocodevault.com/honda/
이 답변이 도움이 되었나요?
점수 6
댓글 달기
keisha, look on the side of the glove box or behind the ash tray for a sticker with a 5 digit code .If its not there then you will need to remove the radio to get the serial number and either call your Honda Dealer for a new number or post it back. You can also try this:
Turn your radio off.
Turn key to the ON position. Do not start, just leave ignition in ON position.
Press and hold the numbers 1 and 6 on your radio with one hand.
Using your other hand, turn the radio on while keeping 1 and 6 pressed.
Ten characters will appear on the screen, usually alphanumeric. Write down all the numbers you see.
Now you can either drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. Or you might want to try this one online. https://radio-navicode.honda.com/
이 답변이 도움이 되었나요?
점수 4
댓글 달기
there is usually a five digit number inside the glove box. when you turn the ignition on and radio read out says error code punch those numbers in using radio buttons this should reset system.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
12154 this is the 2004 Honda Odyssey code I have for my radio
이 답변이 도움이 되었나요?
점수 1
댓글 달기
After you put the five digit code in is it supposed to reset on its own is it something I have to do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
keisha 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 26
전체 시간: 19,239
