주요 콘텐츠로 건너뛰기
The 2000-2006 BMW X5 models were the first generation (E53) of BMW's sport crossover years. The X5 was first released in 1999 for the 2000 model year and featured all-wheel-drive with either an automatic or manual transmission.
19 질문 전체 보기
Why is my crankcasae vent valve smoking
there is smoke coming (from the crankcase vent valve) out the tail pipe
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
What color is the oil . Black or brown like chocolate milk
댓글 달기
답변 2개
가장 유용한 답변
You'll want to take a look at the TSB / SI B 11 08 03. It's a well-known problem for this era of BMW cars including X3 and 5 Series.
Here is a copy that I found:
http://chrisparente.com/Images/530/CCV-S...
By the time I identified it on my X3, I had already blown a head gasket, but hopefully your X5 will avoid a similar fate.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If your engine is smoking out the exhaust, and sucking oil into engine, which I had happen, it is usually a sign that the two CCV hoses which cross over the back of your engine over the intake tubes if engine cover is off on the 4.4 motor X5’s, squeeze hoses, if they are spongy, this is indicator they are restricted and when this happens they suck oil into engine cylinder, as crazy as that sounds, it happened to me. Left side exhaust only. I replace all components and hoses, never had an issue since with over 100K miles driven.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
steven shortridge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 603
