Replaced Logic Board but does not work. (Water damaged phone)
Hey Guys!
My friend has dropped his phone in Turkey and after that he putted it directly in a bag of rise. After 6 days in the bag, it still wont work. I have replaced the Logic Board because i saw on the 'Power IC' that it has some burned bubbles coming up like this -->
http://i1118.photobucket.com/albums/k614...
But after the replacement.. It still not working! I have tested the screen with a test flex cable on a different iphone, and the screen works...
Can you help me please? :D
Thanks in advanced!
Kindly Regards,
Yoenes Pattyn
Update (08/24/2015)
Dear OldTurkey03,
Thanks for the fast response!
I have already done that before, that's why i bought a new logic board, because i thought the logic board has been fried from the Power IC, after that yesterday i checked what Mr. Kyle Halvorson did, and indeed! It has some corrosion aswel on the Charge Port, so i cleaned it with Isopropyl alcohol, let it dry and put back in, but as you already mentioned before.. i have bought a new battery from Ifixit to try if this works! (Hopefully) :( . Otherwise i really dont know what could be else broken.
좋은 질문 입니까?
댓글 3개
mmm... turkey and rice, sounds like a good healthy lunch. not so much for a phone solution though
Bobby 의
Hey guys,
I have received today my new battery for the iphone 4... I putted in, but did not work... I think its the power on - off cable that may be broken? But how do you check that?
yoenes pattyn 의
If power on/off flex is broken or you think it is you can unplug it and power it on through the charging port using a USB cable. This should make the phone come on just for future reference.
Israel 의
