주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006년에 출시된 Kodak의 포인트 앤 슛 카메라.
formatting SD card repeatedly
Continues to format SD cards repeatedly, saying it needs to be formated after each formatting.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Lillie Irene seelye, try a different SD card.C-, M-, V-, and Z-series cameras accept SD and SDHC Cards. SD/SDHC Card Sizes KODAK recommends use of a KODAK SD Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB). Stick with the 2GB cards If that still does not work, you may have to disassemble your camera and check the SD card reader.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
How do I check the SD card reader (what to look for)? I am running into the format looping issue after a drop (I believe), even when using SD cards that have been used with the camera previously (256MB). Also, write protection sometimes gets engaged when putting in the SD card, which might be related
Ingus Valters Briska check the physical aspect of the reader. Check the lever that “feels” for the wite protect. It it bend etc? After that make sure all the solder connections are in order. Sometimes a quick reflow works.
댓글 달기
Use a 2GB card or smaller. I have bought 2GB cards that were really mismarked 4GB cards. They did not work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lillie Irene seelye 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 18
전체 시간: 3,490
