주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
더 이상 Mitsubishi Electric에서 생산하지 않는 Mitsubishi TV의 수리 안내서 및 지원 정보를 확인하세요.
Blue Screen for all inputs
Have blue screen for all inputs on Mitsubishi LT-46265. Have tried all obvious fixes including resets multiple times. Screen works for menus and Internet so that's not it. When resetting, TV recognizes each HDMI device when reconnected but won't display video or audio. Trouble shooting clearly identifies problem is with TV. Need to know if it can be repaired or needs to be thrown out.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 4개
Was anyone able to find a resolution to this? Test picture is good, menus come up but all blue screens for my inputs
의 공유
I found that I could only get a video with an hdmi connection. I converted to that. I feel like there are too many "smart" controls in this model of tv. If someone solves this problem please let me know too!
의 공유
Out of nowhere, none of my hdmi ports work (e.g. DVD player and computer input).
The port for the Wii works though.
Is this this fixable or is this toast?
의 공유
I just replaced my main board on my LT-46249 which is the same series and shares many of the same components and while the TV now boots, recognizes new inputs, and will display a test pic (The Lady) it does not display video input from any HDMI ports despite trying multiple cables and devices known to be good when in use on other TVs.
Has anyone else had this experience?
I bought the main board used and there's a warranty but just wondering if anyone else has advice.
I did see one error code displayed at one point which was '69':
T2W-PWR SHORT PWB-POWER or PWB-NET/ML (VLP41++)
I only saw that error code once and have not seen it again since.
의 공유
댓글 달기
답변 6개
선택된 해법
Paul Avery, start by A/V Reset all Inputs - Press front panel <INPUT> and <VOL (arrow Left)> buttons at the same time and hold for 10 seconds. This should work for your chassis as well "Built into many models is a “Test Picture” that can be accessed from the customer menu. Press <MENU> select “Picture+” then “Test Picture.” A photograph of the “Lady” will be displayed. If a TV picture performance problem exists, it should be evident. Otherwise, the test picture will have demonstrated that the set is capable of a quality display and the problem is likely due to a signal source or other external cause." If you can check to see what your error log listed for an error that occurred in the past.To access the Error Code Log: Press <MENU> <3-5-6-4>
I would not throw it out just yet:-)
Update (09/27/2015)
Check the fuses (blue) for continuity and check the voltages (red) on the connectors. Let us know what you get.
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
oldturkey03, Thanks for the suggestion. Tried it but no luck. Test picture works just fine. Error log lists Usage Time: 1337 Hrs Code: 0048 Status: Happened.
Any other ideas?
의 공유
I am sure we can come up with some more stuff. You pretty good in taking stuff apart? Remove the back on your TV and lets look at the boards. Luckily we at least know that the LCD is ok. The rest are all just board issues. Error code 0048 is usually related to 3.3 and 5v line short which is a problem with the main board. Need images of your boards to see if this is a capacitor issue or something else. Post some with your question. Here is the guide for doing that 기존 질문에 이미지 추가하기 I should have the schematic for this chassis and I will see if I can find where we can check the voltage. No giving up on here:-)
의 공유
I now have sound that corresponds to my WII game plugged into the tv however I get no video. I tried a; DVD player, PS2 and a WII game system. No luck. It prompts me to identify each new system however then it will play the sound for it but no video. I tried to hook it up to an "Antenna" and I will get static and some moving images, not related to the game system. I have not tried connecting via a HDMI cable just through the yellow RCA input. I am baffled. It seems like everything works, just not the connection via RCA cables. I will have to try HDMI cables.
의 공유
Did anyone ever get a resolution to this
의 공유
My Mitsubishi 55 lt-55264. It has to be reset every 2 years exact but now it will not rest.
It show blue bar is on yellow flashing 19 times then repeat. I am stumped this time. Every time it shuts down because of data like wrong colors or data is interfering. Then shuts down. Trying to update or reset with software but this time will not set to factory with snow screen then restart again. I'm stuck
Patrick
의 공유
댓글 달기
I'm having the same problem. I'll look at the fuses in the diagram but I'm leaning towards new main board?
All rca inputs work fine just none of the hdmi inputs.
Please help. I'm good at working with electronics. Even on the circuit level.
I've had some training.
I'm willing to try. Just need some guidance.
I have wd73838…
I also have a fully working wd73638 I can use for parts if it will work.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
David, Did you ever get your fixed? I have the same set and it just happened to me. Thanks.
의 공유
Take out the whole motherboard. Throw in the the oven at 200F for 1 full hour, let cool then reinsert as it was. Fixes all the HDMI a/v and input problems
의 공유
댓글 달기
It's the ballest change it and your tv won't shut off that's if you don't hear the fans if fans arnt running the ballest gets hot and shuts down and if the fans are running it's just a bad ballest
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have a similar problem in that none of my hdmi ports work (e.g. DVD player and computer input).
의 공유
댓글 달기
Hey guys use your component wires and rca wires should be fine
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My TV won't get the RCA to HDMI cable? Y
이 답변이 도움이 되었나요?
점수 0
댓글 달기
did anyone find the solution to the problem whereby only RCA jack inputs work but no HDMI 1-4 ports?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
my screen on my tv needs fix i cant see it that well
의 공유
댓글 달기
답변을 추가하세요
Paul Avery 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 60
전체 시간: 46,137
