주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mitsubishi의 65인치 후면 투사형 TV입니다.
cap values on DM power board
I was getting ready to perform repair for blinking green light on my old Mitsubishi WS-65511. Pulled the DM power board and noticed the values on the caps are 1000uF 25V. I had read to buy replacement caps that are 1000uF 16V so that's what I bought. Any advice as to what to do? I'm confused. Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
jrmcdown, I just double checked the schematic and the 1000uF are all 16V. May be these have been changed once before. You are okay with using the 16V per schematic.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks soldered in the new caps. Unfortunately must be something else. have constant blinking green light now. Thanks for answering my question though. I think the 25V were installed by TV repairman from previous problem.
댓글 달기
Generally, you are safe if you use over-rated caps. So you could replace 16v with 25v or 50v caps, but you wouldn't want to use 16v caps if 25v were required. - I've heard the 16v caps spec'ed by Mitsubishi are under-rated, so generally when being replaced it's a good idea to use 25v or greater.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jrmcdown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 653
