주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
카메라 성능으로 잘 알려진 Windows 폰입니다. Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876으로도 알려져 있습니다.
Phone not switching on
I was using my phone and then it got switched off due to no charge.
I kept it for charging and tried to switch on my phone but since then its not switched on.
It wont switch on due to some reason.Kindly help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Fazal, it is possible that it is just totally discharged. Try a new cable and a different charger. If that does not work, you may have a bad charging connector. In that case, try a new battery or one that has been charged with an external charger to at least get your phone to respond. Consider replacing the charging port. Here is a decent guide for that.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
That video is in no way helpful it doesn't show u how to remove the port I went through the steps a few minutes ago after releasing the 2 screws there is still another part of the flex cable which is behind the speaker and to remove the speaker u would have to break the backcase so my suggestion is to by the back case with the port
의
댓글 달기
답변을 추가하세요
Fazal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 18
전체 시간: 1,024
