주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
식기 세척기 수리와 분해 안내서 및 지원.
lights flashing nothing wprks
Our whirlpool quiet partner ii dishwashers HEATED WASH, NORMAL, AND CANCEL lights were flashing when we got up this morning. Worked fine yesterday. Tried going through the reset cyle and umpluggong it and going back through reset. At a loss for what to try next any advice?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
My whirlpool 2011 has cancel light flashing
댓글 달기
답변 2개
선택된 해법
duane, try to reset your dishwasher first. To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher. For some of the newer dishwasher, those that do not have dedicated 'heat dry' and 'normal' buttons, you push any 3 buttons in the following sequence: 1-2-3-1-2-3-1-2-3, with no more than a second between each button push. That will put the dishwasher in diagnostic mode. Let us know what you get and what exact model your DW is.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
This worked for my Whirlpool dishwasher after I had tried everything for two days! Thank you.
댓글 달기
Afternoon all, I have trying that exact solution for the same problem for the same dishwasher model type.
The "Heater Dry" lights up, but not the "Normal". Other lights that show up are "Pots/Pan", "Rinse","Sani-Rinse", "Heater Dry".
When I push the "Cancel/Drain", you can hear the motor runs.
Not sure if I will need to replace the panel, since the lights on "Normal", and "Light" have are not turning on at all
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
duane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 62
전체 시간: 15,722
