plug on back defective
the plug, (socket) on back is faulty i think, because the cable wont plug in securely so gps keeps coming on and off, power.
좋은 질문입니까?
좋은 질문입니까?
I had this same problem I removed the board and heated it to reflow the solder then reasembled and all was well. Heated it with a heat gun at the port and used heat dissipation tape around the port to protect everything else
이 답변이 도움이 되었나요?
joe, if the cable is no longer properly fitting the usb port, you most likely will have to replace it. It is a standard 5 pin mini-USB connector. Use this guide to get to the board so you can solder a new connector to it.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 893
