주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1998년형 모델은 오리지널 Beetle을 기반으로 제작되었지만, 이전 모델과 비교했을 때 훨씬 더 넓은 실내 공간을 갖추고 있으며 더 발전된 기능들이 탑재되어 있습니다.
Trunk will not open at all
I have a 2003 VW Beetle Convertible. The trunk latch is broken. I cannot open the trunk with remote or key. I opened the rear seat to gain access to the trunk, reach my arm in and the latch is broken. I know this because when I pull on the latch mechanism, it's frozen, will not move at all. Any suggestions on how to get into trunk when latch is broken in the closed position?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
선택된 해법
Hi,
The info in this link may be of interest
http://newbeetle.org/forums/new-beetle-c...
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
It's a really tight fit. In fact the only way I can work on the trunk from the inside is with one arm reaching into the trunk area, rest of my body outside on the back seat. I discovered a round (almost invisible) cap of sorts inside the trunk below and to the right of the emergency release level. From the article you attached I see that this should be another release (a more effective one). I will try it later today. Thank you for the article.
의 공유
This does NOT work for an 2003 Beetle 1.8T.
의 공유
댓글 달기
답변을 추가하세요
Jim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 56
전체 시간: 45,892
