주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
16GB, 32GB, 64GB 저장 용량 옵션으로 출시된 2세대 Apple iPad Wi-Fi 모델의 업데이트 버전에 대한 수리 안내서, 분해 정보, 문제해결 정보를 제공합니다. 2012년 3월에 출시되었습니다. 모델 번호 A1395와 EMC 2560으로 식별할 수 있습니다. 더 작아진 프로세서 다이와 업데이트된 내부 구조를 특징으로 합니다. 수리 시 열을 가하고 조심스럽게 들어 올리는 작업이 필요합니다.
2.4Ghz WiFi Hardware Problem
Hello,
Since fews days, I have big problems with my WiFi connection. My IPAD does not detect WiFi network, except if I'm at less than 50cm of the router.
It was working perfectly before (before what ? I don't know), and I have another IPAD that is perfectly working in the same context. So my conclusion is that the problem is coming from IPAD and not from my router.
So I tried, many software things to understand the problem:
- Reboot,
- Hard reboot
- Reset network settings,
- Reset everything,
- Upgrade IOS version,
Nothing worked. I tried with IOS 7.1.1, then IOS 9.0.2, then 9.1, I have always the same problem. So my conclusion is that it is linked to an hardware problem, rather than a software problem.
Then I configured my wifi routeur to use 5ghz network, and wonderful my IPAD was able to see the network. But if I'm going upstairs in my home, I see the Wifi network but I cannot go to Internet. I'm not sure it is really a problem it is probably linked to 5GHZ networks that are more sensitive to distance than 2.4Ghz.
So my Ipad does not see any 2.4GHz wifi network, except if there are very very close (few centimeters), and does see 5Ghz wifi network (even if it seems to have a distance problem, but I'm not sure).
Because I have no skills in hardware, I do not know which component could be broken. Is it possible that Wifi antenna is broken ? But if it was the case I suppose that I would not be able to see 5Ghz wifi network (I suppose it is the same antenna). Do you have any idea ??
Thank you in advance,
Bill
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi,
This link has an answer which may be relevant to your problem.
iPad 2 has poor signal after a few wireless antenna replacements..
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
It's helpful, thank you.
Does it mean that with a WIFI antenna damaged, we can still have 5Ghz WIFI network, but not 2.4Ghz ? It seems to be weird.
의 공유
Hi,
Not necessarily antenna damaged, (it may be just loose) but possibly the WiFi chip is faulty. According to the other post it is replacable. Plug in module.
의 공유
댓글 달기
Nope…that a configuration bug from Apple. IPAD doesn’t recognize 2.4 ghz wifi any more
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
bill dangerous 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 4,547
