주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 8920은 2008년 Acer, Inc.에서 출시한 노트북 컴퓨터 시리즈입니다. Acer는 대만 신베이시에 본사를 둔 전자 기업입니다. 8920 모델은 Gemstone 시리즈의 일환으로 출시되었으며 Acer에서 생산한 최초의 18.4인치 화면 노트북입니다.
Display is not working
Hello,
after I start my laptop the load-screen is shown for about 10 sec after this the screen turns black. I know the laptop is still working and Windows is loading but without any graphic.
When I connect the laptop with an external Display, it works and I see the desktop external. This means the graphic card works but the laptop-display stays black. When I push the function button with f6 the lightning button the screen appears for some seconds on the laptop-screen and again nothing. What could be the Problem?
Thanks in advance.
Regards
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
the screen resolution iss to hight connect it to an external monitor and change the laptop resolution to 1024 resolution and it will work ..thats it
의
Ik heb de Acer Aspire 8920G uit 2008.. een oudje dus..maar werkt nog goed
Update gedaan met cpu en gpu Nvidia GeForce 9600 GT,maar blijkbaar blijkt deze videokaart niet direct compatibel met het moederbord..het scherm blijft zwart.
Heeft te maken met V-RAM..maar dat is andere koek..enig idee hoe dit compatibel gemaakt kan worden?
의
댓글 달기
답변 3개
선택된 해법
YET, sounds like a backlight issue. This could be related to the screen or the inverter. I would start with a new inverter. Relatively inexpensive and not very difficult to change. Thsi video will give you an idea of what you are looking at.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you oldturkey03. I will change the inverter in a few days. After this I will come back. :D
의
댓글 달기
I changed the inverter and the problem is still there. Now Im sure it should be the screen itself.
Thank You.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had same problem on my Aspire 8920g in 2013. Just want to share my solution.
oldturkey03 is right that the problem is with backlight.
I solved it in two steps. Starting with easiest.
First - replace inverter, in my case the problem was still there, but for some users it can be solution.
Second - replace LCD CCFL Backlight. This step is more difficult, but with patience and skilled hand it is less than 2 hour job. To change CCFL is cheaper than whole screen.
You can find them for under $20, just search eBay for "LCD CCFL Backlight Aspire 8920",
example eBay link
I did this repair in 2013 and still PC is working without problems.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
YET 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 36
전체 시간: 3,708
