주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Red Ryder BB Gun은 Daisy Outdoor Products에서 1938년에 출시한 BB 건으로, 서부 영화에 등장하는 윈체스터 소총을 닮았습니다.
No pressure to fire
Trying to shoot my daisy red ryder air gun but it wont build any pressure to shoot. How can I fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
i would like to find 2 repair kits for Daisy model 1938B Red Ryder 70th Ann. Edition.
의 공유
댓글 달기
답변 5개
가장 유용한 답변
stephanie bryant if this is an older BB gun then it could be caused by dried out seals, bad springs or a leaky air chamber. If you tell us what model your Daisy is we can most likely get you more information on it.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
I have a Red Ryder from the 1970s that is super weak but still works. Where can I find the spring and seals for a rebuild? Mark.Fort@att.net?
의 공유
Fairly new jr red Ryder pops like air pressure but nothing comes out
의 공유
It's probably a jam and or a broken compression chamber. "You'll shoot your eye out"
의 공유
댓글 달기
Broken spring or plugged barrel
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have a 2000 Millennium Edition Barrel plugged up with BB's. Every things off the gun, don't know how to take Barrel out.
의 공유
댓글 달기
Maybe the issue is related to mechanical failures or plunger and the lever not connecting
이 답변이 도움이 되었나요?
점수 0
댓글 달기
To reload a Red Ryder Bb gun, you have to hold the gun pointing up while reloading--that is, cocking--the gun. (This allows the pellets to be brought into position to be fired.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Bought the Red Rider gun at wal mart just right before Christmas. I shot it no more than 4 times. The cocking mechanism jammed it is now loose but will not fill the gun with air. I kve the gun but I am very disappointed how soon it broke and I cannot use
Brenda Shelby
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have had this same problem. Take out the trigger assemble and check to see if the spring that holds up the main spring draw back bar is broken. The plastic part is usually broken. Parts are available from Dasy or other venders.
의 공유
댓글 달기
답변을 추가하세요
stephanie bryant 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 84
전체 시간: 16,631
