주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Micromax Canvas 2 Plus A110Q는 2013년 5월에 Micromax Mobile에서 출시한 듀얼 SIM 안드로이드 스마트폰입니다.
facing OS system issue
I have a Micromax A110Q Canvas 2 Plus phone whenever I start the phone the canvas word comes on the screen as if it is starting but it gets stuck to that only & my phone doesn't start. The display remains the same i.e. canvas written on the screen. nothing happens after this.
Kindly Help.
Regards,
Ratan Singh.
singh.ratan012@gmail.com
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
I have done the same but nothing changes still whenever I switch on my phone screen comes p by writing canvas on it & after that it gets stuck nothing happens later to this.
의 공유
Hi,
I found this link which may be of interest to you. http://forum.droidarena.in/Thread-How-to... First he states that you press 3 keys (power + vol up + vol down) to hard reset. Different to what I have found (and you as well) elsewhere. Maybe you could try that before deciding IF you want to try his other option.
의 공유
댓글 달기
답변 1개
선택된 해법
Hi,
You need to hard reset your phone.
Before you do this make sure that the battery is fully charged.
Warning : A hard reset will restore your phone to factory default. You will lose all downloaded apps and user data!
To perform a hard reset do the following:
1.Turn off your phone
2. Press and hold the Volume Up + Power button (both together) until you see Recovery mode.
3. Release both buttons.
4. Select option "wipe data/factory reset" from the menu.
(To scroll options use Volume buttons, and to confirm press Volume Up key for 3 seconds).
5. Then confirm "yes" by Volume Up.
6. In the end accept (confirm with Volume Up key) operation "reboot system now"
The phone should now reset, be patient it takes a few minutes.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Rats 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 359
