주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keurig K75 Platinum 브루잉 시스템은 Keurig에서 만든 프리미엄 가정용 1컵 커피 브루잉 시스템입니다.
reservoir refilling from the machine
Why is my reservoir refilling from the machine. It'll draw water in and then a small amount will brew out with the most of the hot water returning to the reservoir through the intake or overflow. It's as if a check valve is open.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Paul, this is most commonly caused when the discharge tube backs up because of clogged lines, check valves or clogged needles. The water then comes out of the overflow tube back into the reservoir. Try cleaning it by following this guide.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
When I selected a large mine (a B60) would pump about 6 ounces, and then the rest would flow back to the tank through the vent/overflow line. None of the regular repairs helped. I tried descaling, cleaning needles, banging it around every way conceivable, blowing air into both the holes on the vent, and removing and cleaning the top check valve. Then I took the bottom off and saw there is a simple check valve on the pump discharge. It has a rubber nipple in it which I pried out with tweezers after removing three screws and splitting the housing. There were blisters on the rubber nipple preventing it from operating properly. I punctured the top layer of rubber on the blisters from the outside with a sewing needle and squeezed out the trapped water. Reassembled the unit and now it is working fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Paul 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 31
전체 시간: 16,198
