Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
좋은 질문입니까?
좋은 질문입니까?
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The 2003 Mazda Tribute with the 2.0L 4-cylinder does not use a traditional Engine Coolant Temperature (ECT) sensor that sits submerged in antifreeze. It uses a Cylinder Head Temperature (CHT) sensor that measures the temperature of the metal itself, and the computer uses that reading to calculate the coolant temperature.
이 답변이 도움이 되었나요?
Yes it's the coolant temperature sensor
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 13
지난 30일: 44
전체 시간: 9,987
댓글 4개
Where is the heat sensor located on Mazda tribute 2003-2007?
Lavianna Stoops 의 공유
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
Ferdinand Quijon 의 공유
Where is the heat sensor located?
Any video available?
SOLOMON POKU-ASARE 의 공유
