주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore Elite HE3는 Kenmore의 세탁기입니다. Whirlpool Duet과 동일한 모델입니다.
meaning of OE code
getting OE code and does not drain/spin
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
@ronhurley the error code "OE" is a "Drain error " and it is initiated by your washer not having fully drained in 10 minutes. Most common cause is a clogged filter. Check your "coin trap" filter for retained objects, like missing socks etc.:-)
To clean it
1. Take off the lower front panel
2. Turn the pump filter cover counter-clockwise by hand and remove. Place a bucket or pan underneath it since you will get water spilling out of there.
3. With a set of long pliers, remove the filter. Clean that of any debris etc. and replace it when cleaned.
4. Replace the filter cover and lower panel.
The other thing that could be going on here, is that the drain pump is not working and needing to be replaced. The service manual will have instructions on how to do that. There is also a decent video on here.
There will be plenty of water. So please make sure that you have lots of buckets and towels etc. to catch the water. It will be a stinky, dirty flood
You can download the service manual from from here.
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 6
댓글 10개:
Have cleaned outf ilter blow hose clean still same fault
의
I followed this and didn’t fix anything. I am guessing the pump is clogged or not running at all...good luck
의
Worked for me , I just hope it stays working! Thanks
의
I had to replace the drain pump, 20 something bucks on Amazon. Not to hard but can be challenging for some. Fixed the problem.
의
Thank you so much. This did the trick!
의
댓글 5개 더보기
댓글 달기
답변을 추가하세요
rhurley52 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 58
지난 30일: 269
전체 시간: 122,527
