주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision M4600은 2011년에서 2013년 사이에 Dell에서 출시한 15.6인치 노트북으로, 강력한 처리 능력을 갖춘 Dell 모바일 워크스테이션 시리즈의 일환입니다.
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
의 공유
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
의 공유
I`ll replace my screen and feed you back with the results. Thanks Man
의 공유
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
의 공유
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
의 공유
댓글 4개 더보기
댓글 달기
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mahmoud eldeep 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 44
전체 시간: 9,357
