주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP의 LaserJet 레이저 프린터 제품군에 대한 수리 안내서 및 지원입니다. 이 제품군에는 LaserJet, LaserJet Pro, Color LaserJet, P, M, CP 및 CM으로 시작하는 모델 번호를 가진 프린터가 포함됩니다.
Paper Jam , none seen
Says it has a paper jam, none can be found. Looks clear
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
no Jam but says there is a jam in Tray 1. my e-mail:ptlovett123@gmail.com
의 공유
댓글 달기
답변 2개
가장 유용한 답변
You can go to HP.com, look up your particular printer and find the most suspect area for a paper jam. It could be several places. As the paper traverses the paper path, it is timed. if the leading edge doesn’t get someplace on time, it will fault out. It could be your paper pickup rollers, or several other places depending on your make and model. LaserJet 4’s are notorious for output jams, for instance. Also, there could be a tiny piece of paper torn off and jammed into a corner somewhere that catches the next feed. So, if Mr. Knight’s fix doesn’t work, please post what type of printer it is (LaserJet 4, Colorjet 4030). What error code you receive on the display. The age of the printer. If it is an old printer, it is probably the paper pick up rollers. YouTube is also a good source of info for this type of problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
As the paper comes up from the paper tray, it goes through a register under the print cartridge. If it is stopping there before being pulled further into the printer, make sure that all parts of the register assembly move freely. I’ve seen the little felt pad stickers that are placed in different sections of the printer to dampen noise lose their felt over time and become sticky. Parts that touch them become stuck and cause the paper to not be noticed by the register. So turn-off the printer and remove the print cartridge. Look at the roller under it. there will be some metal plates near it. Make sure they move as they should . They are spring-loaded and should be able to flip or rotate forward/back. if you do find the sticky pads (about the size of your small finger’s fingernail), scrape them off.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
fdzwiesele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 11
전체 시간: 421
