주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why does vertical line appear on documents using ADF as source
If I copy from the flatbed everything works fine. However if I copy or scan using the ADF, then a black vertical line appears down the center of the output document.
I wonder if there is dust or dirt in the ADF causing the line to appear, if so where can I find instructions for opening and cleaning ADF.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 9개
Didnt work. Cleaned the entire ADF area and nothing helped
의
Cleaning didnt work. The line is very straight, top to bottom, not smudged like dirt. Almost like a scratch.
의
cleaning did not work. is there any other solution
의
I have no narrow strip of glass on my scanner
의
IT WORKED! Cleaned the small space of my Epson WF-3530 with alcohol and cotton ball. My documents (scanned, copied, faxed) have had red streaks for over 2 years or so.
I'm excited the problem is solved and was free to resolve. :)
의
댓글 4개 더보기
댓글 달기
답변 4개
선택된 해법
Hi,
Here is a link to the User Manual that shows how to clean the ADF area and rollers. Scroll down to Cleaning and Transporting your Product, click to open then click on Cleaning your Product
https://files.support.epson.com/docid/cp...
이 답변이 도움이 되었나요?
점수 16
댓글 14개:
clean the small glass. worked!
의
Cleaning the small glass worked. Thank you
의
This is so cool!! thank you!!!
의
yes cleaning glass did the trick . thanks
의
Cleaning the narrow strip of glass on the left worked - also vacuumed the left side to remove dust. - Thanks
의
댓글 9개 더보기
댓글 달기
This problem occurred with my Epson WP-4530 when using the ADF to scan. Epson manual says to avoid chemical when cleaning the ADF, but I could only remove the lines by using alcohol. Dry cleanig wold not work, but alcohol worked great!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you, thank you! I removed the lines using rubbing alcohol and a microfibre cloth on the glass, the clear plastic on the ADF, and all around the clear plastic on the ADF. Clear as a bell now!!
의
댓글 달기
It took spraying condensed air on the rollers to clear up my problem.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Cleaned small glass panel on left. Small ink blot removed with alcohol. Removed line on feeder and feeder scan copies.
의
댓글 달기
Tried wiping the ‘small glass panel on left’ with a dry cloth but this didn’t help. Went at it again with a cloth dampened with alcohol screen cleaner and problem solved.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Like some others who've posted, I inspected the small glass panel...subtle amounts of schmutz on it. Took some Windex and elbow grease to remove it. BUT......the effort was worth it......the two vertical black streaks on all my ADF-scanned documents were GONE !
Thanks for the suggestion.
의
After using microfiber with alcohol it's gone.
의
댓글 달기
답변을 추가하세요
rglee46 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 54
전체 시간: 40,933
