Can I fit a second disk drive
I want to fit a second drive but I only have one socket on the motherboard
좋은 질문입니까?
좋은 질문입니까?
The XPS 420 has 5 SATA sockets on the motherboard, labelled SATA0 ... SATA4.
Your primary HDD should be connected to SATA0. A secondary hard drive should be connected to SATA1. Other devices such as optical drives should be connected to the remaining SATA sockets.
SATA0 and SATA1 sockets are located next to the RAM slots, toward the rear side of the computer.
The other SATA sockets are a few inches below.
The computer has 2 slots ("bays") for hard disk drives, near the bottom of the enclosure. One slot is occupied by the existing primary drive. The other slot should be available for an additional drive, and it should have a power connector already in place.
To fit a standard 3.5" HDD in the second slot, you need a mounting bracket. This is the blue piece of plastic that allows the drive to slide and snap in. It may already be factory fitted in the empty bay. If you don't have one, you can get it as a spare. Amazon probably has them. Search for "Dell XPS 420 HDD bracket". You also need a SATA cable, with a straight plug on one end and a right angle plug on the other end, about 2" long.
The user manual for the XPS 420 is available here. The procedure for adding the second hard disk drive is on page 132.
이 답변이 도움이 되었나요?
You can also install a hard drive in the Flex bay (just below the main CD/DVD drive bays) if they are not occupied, turn the black nob on the side to the back of the flex bay so the square is in the bay you are planing to use points toward the back. then use the 4 screws on the blank panel to mount it like a normal drive (just push in and connect it). The supply should have some spare sata connectors that are not being used.
Hi,
Here is a link to the Owner's manual for your desktop.
Scroll down to p.103-104, it shows that there are 5 sata ports on the motherboard. (#3 + #6 on the motherboard layout)
If you want to fit a 2nd HDD there are at least 3 spare ports available for you to use, if your current arrangement is only 1xHDD + 1xODD, unless you have more sata connected devices installed.
이 답변이 도움이 되었나요?
The Dell XPS 480 is the perfect computer for adding additional HDD's.
You can add up to 3 additional drives giving you loads more storage if required.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 11
지난 30일: 22
전체 시간: 2,039
