주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
13.3인치 플립형 터치스크린 노트북 (SVF13NA1UL).
Display blink, problem with intel graphic driver
I try update to new driver, i try roll back old driver, but display still blinking. Only work when graphic card is disabled, but then brightness control dont work, and battery life is only 30 mins. Any fix?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개:
Everyone says is only driver? If conctor is broken, display will not work when i disable drivers?!
nastic, exactly what do you mean by blinking? Does it do it all the time? It stops blinking when you disable the graphic card? How do you do that? What do you get when you connect an external monitor?
does the problem happen when the battery is connected? I would look for info on how to do a power flush on the laptop, I'm looking but can't find anything. this has fixed issues like this for Dell machines in my experience.
Sony Vaio Fit 13A Troubleshooting
@oldturkey03 i just disable from device manager. Its happend in both ways, on battery or cable
This is exactly what i am experiencing now, did you find any solutions?
댓글 달기
답변 1개
Hello Nastic
Im my opinion by what you wrote the display conector inside your Laptop are probably damaged from the inside and the battery that means its damaged or the laptop is not getting the voltage that it needs
HOPE THIS HELPS :D
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It works when the GPU is disabled.
댓글 달기
답변을 추가하세요
nastic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 24
전체 시간: 1,772
