주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola E815는 Motorola에서 출시한 플립형 카메라 폰입니다.
How to retrieve the memory
I have an old phone and was wondering if it was possible to save that voicemail storage text messages contact information phone call memory etc.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
@shane7702 only if you can still access your phone. You would either need a phone-to-Computer cable (or check to see if your computer has a bluetooth connection, and the Motorola File Manager software.
1. Connect to Motorola Phone Tools.
2. In the Folders pane, access the folder where the message you want to save is saved (Inbox, Sent Messages...)
3. Select the message you want to save.
4. In the File menu, select the Save as option.
5. Rename your document (if you want to) in the File name box. (.txt format is displayed by default)
6. Select the folder path where you want to save your document if the selected folder does not suit you.
7. Click the Save button.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Shane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 380
