주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Harmony 650은 Logitech에서 제조한 만능 리모콘입니다. 컬러 스마트 디스플레이로 가장 잘 알려져 있습니다.
My remote keeps resetting its self
My Logitech Harmony keeps resetting itself. I don't know why this keeps happening. What is causing this to happen, and how can I fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 5개
선택된 해법
The problem could be that your battery connectors are faulty. This is actually a common problem with this specific device. Check to make sure that the batteries are well seated in the remote, and if that doesn't work check to see if the connectors move when you touch them. If they do move then you will either have to repair or replace them. For help in doing so check out the troubleshooting guide.
이 답변이 도움이 되었나요?
점수 6
댓글 2개:
It may just be the batteries are flat as well. The remote seems to work fine with the screen lit up but if the batteries are flat and you send some commands, the remote will reset - at least that is just what happened to mine this evening.
의
@Kyle, thanks. Worked after batteries replacment
의
댓글 달기
After trying the above solutions, simply putting in new batteries totally fixed this problem for me.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
To keep the batteries better seated between the contacts, I put a small, narrow piece of foam packaging (1/16-1/8” thick) that’s about the size of two postage stamps over the batteries and gently closed the battery cover over it. The batteries seem much secure as I shake the remote.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Instead of replacing the faulty battery contact thingy, I just wedged a square of tinfoil between the battery and the positive contacts. Voila. Works like a charm.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
How exactly did you do that? Did you have to disassemble the remote? Thanks Jude!
의
i took Jude's idea: folded a small piece of aluminum foil about the size of the top of the AA battery, held it on the (+) connector by wrapping scotch tape around the rim. Seems to have stopped rebooting. A more permanent solution will be to affix the foil inside the remote instead of on the batteries.
의
I thought I had to buy another Remote because it constantly lost its connection with our equipment. Then I tried this fix!
I had the same great result wedging in a piece of folded aluminum foil between each of the batteries and the Remotes battery connector. Now my Remote works great. Thanks Jude for this simple fix!
의
댓글 달기
I created a small hook from a paper clip. Gave a little tug on each of the connectors inside the device.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Austin K 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 37
전체 시간: 40,996
