주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
네 번째 Google Nexus 스마트폰, 2012년 11월 13일 출시.
Touch Screen Not Working After Back Glass Replacement
I recently replaced the back cover and glass on my LG Nexus 4. It turns on but the screen doesn't sense touch. If I take the back cover off, it works just fine, and if I put the cover on while its already booted, it works just fine. What's the deal? Help?!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 2개
Ok, I've narrowed it down the the two bottom screws that hold the back cover on. When they are removed, everything goes fine. But still... Whats the deal?
의
Hi, Either the back cover, with the screws in, is compressing something which may be either making it touch something else or it is pushing it loose. An example would be of a connector plug pushed into its' socket then something coming next to it pushing the board so the socket moves away while the plug stays. Also if there is a metal strip or something similar (I don't know, you can see) on the inside of the back cover it may be shorting something out.
의
댓글 달기
답변 1개
선택된 해법
Turns out the screws on the bottoms holding the back cover on, were just too tight. Loosened them, and problem solved.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dalton Prokott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 410
