주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년에 출시된 TDK Life on Record A26은 블루투스 및 스피커폰 기능을 갖춘 작고 방수가 되는 휴대용 스피커입니다.
What does flashing lights mean?
I turn on the hard switch and push the power button, after three seconds the bluetooth and auxiliary buttons flash. Then device turns off and does not work. Is there a way to fix this? It is an error code but I can not find what it means. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 9개
please supply error code
의 공유
The error code is the simultaneous three flashes of the auxiliary and bluetooth buttons. I do not know what that signifies but if you are a computer literate you would understand that it is an error code.
의 공유
Hi, I realized it was an error code but thought perhaps a reset might clear it
의 공유
Yeah, I tried the reset again, regardless. Still didn't help.
의 공유
Hi,
Can't find any info regarding error codes, so am trying to eliminate possibilities. All these questions relate to establishing whether there is a problem with the battery and or the charging circuitry of the speaker.
1. What happens when you only connect a charger that is powered on? 2. Does the correct charging light i.e. red or amber show? 3. If red does it eventually change to amber? 4. Does it work properly when fully charged? 5. If not does it work properly when connected to the charger?
If the above do not point to a problem with the power:
Have you tried disconnecting the battery for a short period and then reconnecting it to see if this clears the problem? Here is a link that shows how to unplug the battery http://downloads.imationsupport.com/lor/...
2 part answer
의 공유
댓글 4개 더보기
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Here is a link that shows how to reset your A26.
http://support.tdkperformance.com/articl...
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tyler Pratt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 28
전체 시간: 1,848
