주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
세탁기 수리에 도움이 되는 안내서 및 지원 문서 모음입니다.
Washing machine pouring water continuesly
Hello..I am using fully automatic top load washing machine Panasonic NA-F70B2 ...yesterday it suddenly had a blast after few minutes of cycle started...I saw lil smoke and smell coming out of it...i call a repairman...he replaced the inlet valve and the fuse...then i turned it on and the water started immediately even before i adjusted any program...and won't stop while overflowing... then he replaced the pressure switch... but the problem remains..he is saying the main control panel is gone...but everything else is working fine other than the water supply problem...can it really be the control panel?
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개
@msuns can you add a couple of images of your control board and the area where you think the smell is strongest? Use this guide 기존 질문에 이미지 추가하기 for that. Also, what exact model is your washer?
의
@oldturkey03 I added the photos...the model of my washing machine is Panasonic NA-F70B2...There was a strong smell in the inlet valve which I replaces...but the is still burnt smell in the white port in the picture...
의
Oh it's the same predicament of my Panasonic Automatic washing, I replaced the inlet valve with an original part, still the water continues to pour in into the drum.
I check everything the hose, the main drain if there are clogged thing on it.
Its the main mother electronic board that is already defective or it's time to retire. I bought my unit in June 26,2016 and it's now September 21,2026. The machine is retired. It no longwr function as it was before, the button I need to press it many times before it started to light it's indicator.
The mother board it's useless to order it, it's like buying a new unit.
의
This is a disaster. You're only way out of here begins with locating the part which burned and identifying it. Since the images you provided do not show any burnt markings, you need to keep looking.
의
The issue on machine was solved successfully after replacement of transistor which failed on the board in open position.
의
댓글 달기
답변 4개
가장 유용한 답변
Sounds to me like the water level switch has failed. Take a look at the main control board and other components to see if you can any visual evidence of where the smoke was coming from (burnt insulation), and let us know.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
The burnt smell is strongest in the port that joining the inlet valve. I replaced both inlet valve and water level switch. But no luck.
의
I have the same washing machine, with the same fault. The problem is not in the water level switch or the solenoid. The problem is originating somewhere in the two electronic control boards. I need the circuit diagram of these electronic control boards of Panasonic NA-F70B2, any idea where I can get hold of one copy???
의
댓글 달기
@msuns, check the wiring to the connector. Follow the wiring guide. Also, check the connector with a multimeter. It sounds like it continuously excites the solenoid on the water inlet valve. You need to set your multimeter to the voltage settings that are appropriate for your household (whatever country this may be:-)This could be by shorted wires as well as a failed control panel. If it is the control panel than you should not have anything at the connector end. That failure would be most evident in the control panel. Do also check the water level sensor to ensure that it does not send a continuous signal.
이미지
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 달기
The valve is a solenoid , basically a coil of wire with a rod or actuator in this case. The coil on the solenoid is cooked. That is how the valve works. If it is a new valve (solenoid valve) and is still not operating then the guy is right . The part of the board that controls the solenoid is cooked. An electronics tech worth his salt could repair it or you could be lucky and the board has a fuse cooked on it. ( usually 120v items are fused) Does the water still run without the run on ? The actuator could be stuck as well , which is why the fuse blew and still doesn't work. See what voltage if any is going to the valve? I would guess it's something simple, but bad luck w a board is always possible . Keep posting I will keep an eye out for ya and let us know
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I am facing exactly the same issue with the same model washing machine...
의
댓글 달기
mine too the same problem.
2.5V present at water level sensor when old or new water sensor is fix the supply voltage dropped at 0.5V thus water continues to pour endlessly.
i replaced also the inverter IC, which is from mcu to inverter IC then to water sensor still no luck
i don't know now looks like the control panel is defective and fully need to be replaced
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I got the machine repaired from a local shop. A switching transistor was blown in the open position. It is now working great.
의
댓글 달기
답변을 추가하세요
Nusrat Jahan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 55
전체 시간: 5,916
