주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세에서 5세 어린이를 위해 VTech에서 제작한 교육용 어린이 장난감입니다. VTech Little Apps Tablet의 모델 번호는 80-139400입니다.
Why is my screen so dim?
The screen is too hard to see in low light conditions and makes the tablet almost impossible to use. Is there anyway to change this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
The VTech Little Apps Tablet comes with an option to toggle through the LED back light colors which should assist in low light viewing. The most simple solution to this problem would be to change the back light color. Referring to the troubleshooting page will assist you with doing this. If the LED's won't turn on or change colors when you toggle the settings, they may be broken, in which case the solution is also found on the troubleshooting page.
If changing the LED back light settings doesn't completely fix the problem, adjusting the brightness settings may help.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
There is no button above the OK button that has any thing to do with changing backlight colors! And there is no dedicated button for backlight!
댓글 달기
답변을 추가하세요
Dakota Wiersma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 31
전체 시간: 2,698
