주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why is there static noise?
There is a horrible static sound whenever I turn my speaker on. No matter the volume, high or low, I can’t hear the music over the static sound. Do the speakers need replacing, or could something else be causing the unwanted static?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 3개
The answer said nothing about hard wired speakers which is where my problem is. That said, since it is an old Sony receiver, and static is in all speakers, is is possible the receiver is to blame or is this a wire problem.
의
My hoverboard has been making a static noise since I went into a ditch, on a narrow pathway. I don't get what is the matter , but I need to know asap if the speakers need changing.
의
static noise only on set ups that is it for over 3 months
의
댓글 달기
답변 5개
선택된 해법
Hi,
Try connecting the speaker to a music source using a stereo audio cable plugged into the Line In Audio socket of the speaker and the headphone socket of a mobile phone (for example).
If there is no noise, there may be a problem with the Bluetooth connection. Remove any pairing connections stored in the speaker and also the Bluetooth device (e.g. phone) (see previous answer to you with User Guide link) then re-pair with the Bluetooth source and see if it is still noisy.
If it is still noisy, remove the Bluetooth connection 'stored in the speaker and try pairing with a different Bluetooth device, (ensure that the 1st Bluetooth device has the Bluetooth turned off) and see if the noise is still present.
If there is noise when using both the Bluetooth and the stereo cable there is a problem within the speaker. There are a lot of things in a powered speaker which, if faulty, can produce unwanted noise and it would have to be opened so that it could be checked to see what is causing the problem
이 답변이 도움이 되었나요?
점수 7
댓글 1개:
This was super helpful, thank you so much
의
댓글 달기
Hi,
Static sound is often caused by connectivity issues to the Wi-Fi. Make sure that the speaker is within proper range to the nearest router, around 100-150 feet. This will ensure a good connection via Bluetooth, and the static sound should dissolve.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I tried this, it did not work.
의
댓글 달기
Hi,
Static sound may be caused by dirt and/or dust build-up in the device. Use a condensed air-duster to clear away the dirt/dust from inside the speaker.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
For my sb571 The sound breaks when it is played at high volume what should be done
의
Please troubleshooting
의
댓글 달기
No its a wire shortage or either your wires in the speaker are damaged
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It's brand new strait out of the box
의
댓글 달기
Hi,
Solved this problem, this is how…
Connected a old Asus mobile charger and humming noise disappeared during charging…this adapter was a 5years old one.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Yana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 58
전체 시간: 88,361
