주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X220. 2011년 4월에 출시된 비즈니스 노트북입니다. 이 12.5인치 노트북은 2.1GHz Intel Core i3 프로세서부터 최대 2.7GHz Intel Core i7-2640M 프로세서 및 Intel 통합 그래픽까지 다양한 사양으로 구성할 수 있습니다.
Why is my touchpad jumpy?
When using my touchpad it will jump all over the screen. I have cleaned it and it is still happening. What could be causing this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi, What OS is installed in your laptop, Win7, 8.1 or 10?
의 공유
댓글 달기
답변 3개
선택된 해법
You may need to update your mouse settings. You will find this in your control panel, under hardware and sound. You will then go to device manager which is under devices and printers. Another window will pop up and you will right click on mice and other pointing devices. A button will pop up, scan for hardware changes. This will update your mouse to most recent device settings. It may take a moment. If this doesn’t work you may need to slow down the pointer speed on your mouse.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Jittery touchpad causing erratic mouse control is most often caused by poor grounding, especially when the issue comes on suddenly. Over time, the internal buffering (such as a capacitor failure) of power likely starts to fail. Use a buffered power strip and the mouse cursor should behave better.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
try reinstalling the windows and check if pad is working okay. If still problem appears after updating the PC in settings>update & security, Then, Go to lenovo official website. download lenovo service bridge and lenovo system update. Let the Lenovo system update app handle the rest. keep your device connected to charge and ensure not to interrupt because your bios will be flashed and updated. Don't select / mark the option Download deferred only in Lenovo update window. after every update, restart will be required several times. every time, manually open the app and check for next update. 3 or 4 software and firmware updates and boom - you problem solved after final restart demanded by pc itself after some time.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Emily Heffernan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 43
전체 시간: 11,100
