주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 4월 출시, 모델명 A10-70F로도 알려져 있습니다('F'는 Wi-Fi 전용 모델임을 의미함).
How to change camera mode
How do I change from front facing camera to back camera?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 14
댓글 1개
If you switch the tablet off and switch it back on and hold the on switch for 5 seconds the camera icon returns and you can alter it
C
의 공유
댓글 달기
답변 2개
선택된 해법
Hi,
This shows how to switch cameras in your tablet.
이미지
이 답변이 도움이 되었나요?
점수 4
댓글 6개:
The switch mode dissapeared!
의 공유
I am having the same problem, are we missing an update??
의 공유
Hi, Have you tried backing up your tab and then performing a hard reset to see if it restores the camera switch function? If it comes back after a hard reset, restore your tab using the backup you made earlier and then see if it is still there. If not perhaps a downloaded app is causing the problem
의 공유
Downloaded another camera app. Same problem!
의 공유
Hi Hugh Norris,
If you have done a factory restore, (after backing up your tablet first) and the switch option still doesn't appear you may have a hardware fault with the back camera. It may be that the software 'interrogates' the camera to check if it is there and functioning OK (up to a point i.e. can it be accessed and does it respond, not can it take pictures OK) and if not will not allow it to be connected to because it doesn't respond. This is conjecture on my part, but not an unreasonable thing for software to be able to do.
의 공유
댓글 1개 더보기
댓글 달기
I lost my front camera and, after trying for some time I realised that the icon was missing. In the end I installed a scanner app (which uses the front camera) and when I opened it, my tablet had reverted to the front camera and the icon was available to make the switch.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
What scanner app did you downloaded?
의 공유
댓글 달기
답변을 추가하세요
danabluemoon77 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 36,332
