주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google이 설계하고 LG가 제조한 6세대 Android 스마트폰. 모델 LG-H790. 2015년 10월 출시.
ghost touchscreen inputs due to water
I got some water into my phone and the screen has been wonky since then. Sometimes it behaves like normal, but most of the times it does this thing where random touch inputs occur in a column in the middle of the screen.
Edit: It seems like the orientation of the phone has something to do with the touch inputs. When I leave it screen down for a period of time it's fine, but if I turn it screen up, after a while the random inputs start occurring again.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi
Me also got the same problem. do you have any idea why its happening and how t get rid of it
의
댓글 달기
답변 2개
the phone needs to be treated for the water damage. its more than likely there is damage on the board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
if your handy with a tools and have access to home depot. Grap some denatured alcohol and toothbrush(assuming you dont have an ultra sonic cleaner) . Disassemble the phone and look for signs of corrosion . More than likely you will find it on the screen or digitizer's connector or the main board. Clean with denatured alcohol with toothbrush . Brush all connectors throughly as well as the main board itself. Let it dry and reassemble and test. If problems still persist you might require main board repair or new digitizer.
- www.orlogicrepairs.com
MacBook repairs in VA
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I disassembled it as far as I could without using a heat gun and I found no signs of water damage on the main board, so the damage is most likely in the digitizer.
의
댓글 달기
답변을 추가하세요
Jason Wu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 8
전체 시간: 1,502
