Why does nothing appear on desktop?
I am reposting my question from Apple Discussions to see if someone here may have a little more insight into the problem. Here is the thread:
http://discussions.apple.com/thread.jspa...
To update.... applications will no longer open. Just my desktop photo with nothing but the dock appears. The fans will occasionally come on full tilt and run for awhile that way and eventually slow down. Back when Temperature Monitor still functioned I was getting some pretty high temp readings, in excess of 75 degrees C. Just this morning I tried to run TechTool 3.1.3 from my iBook (target disk mode). the iMac's HD mounted on the iBook's desktop but TechTool was unable to detect the volume.
At this point, I have the back cover off of the iMac and am looking at the capacitors. Some of them look a little puffy around the crosses compared to the rest. I'm wondering if it would be worth the cost to replace the caps?
I am grateful to anyone who is willing to take the time to read and give me some input on this issue.
Thankfully,
Randy
좋은 질문입니까?
댓글 2개
Thanks for the reply. I'll check out the link you posted. I'm actually considering doing the repair myself with this information,
http://jimwarholic.com/2008/07/how-to-re...
I think it was you who posted this in another question. I take it from your reply that you're pretty sure my problem is the caps.
It does seem like Apple should own up to this mistake and continue the repair extension. There are so many of us with those iMac G5s out there. Is it only a matter of time before they are all effected by the bad caps?
Randy
randy3833 의
Here is a list of the bad cap serial numbers that Apple identified:
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
mayer 의
