주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple은 2013년 11월 1일, 더 얇고 성능이 향상된 iPad Air를 스페이스 그레이와 실버 색상으로 출시했습니다. 커스텀 A7 프로세서를 탑재했으며 16, 32, 64, 128 GB 구성으로 제공됩니다.
How to bypass the iPad passcode
Hello everyone! My grandmother just got an iPad recently and managed to put a passcode on it and not remember what the passcode is. I have tried putting the iPad into recovery mode and restoring it. However, there is an error every time I try to do this. In addition, I have tried using icloud. To erase the iPad, you need wifi and she has disabled it by trying her passcode to the point where it says "connect to itunes" like it is permanently disabled. PLEASE HELP!!!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
do i need to have an internet connection while doing this action and connect to the PC?
의
댓글 달기
답변 6개
가장 유용한 답변
While you try to restore the I-pad, Take it to DFU mode and try to restore it.
DFU Mode: Press the Power button and Home Button at the same time till screen goes off,
After 5 secs of doing that, leave the power button and just press the home button till
it goes to DFU mode. After that, try to restore the I-Pad
Hope it Works.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Follow what Patrick said, make sure the iPad is DFU mode otherwise it will not work. Make sure you are using an original apple charging cord, if it doesn't work the first time try another charging cord or computer, sometime your settings on the computer will prevent the new software from going into the iPad properly.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you wish on a star you can do anything in one click.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
There is a "what" error when you try to restore?
Be specific enough please.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
A program named 4uKey works for that issue.
bypass ipad passcode in 1 click.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Can the program bring peace to the world in one click too ?
의
댓글 달기
In such a situation, you can try an iPad passcode unlocker to help you. There are many such tools online. I have ever used one called Joyoshare iPasscode Unlocker to factory reset my locked iPad. It is easy to use. Of course, you can google this kind of unlocking tool and choose one that you desire.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
morganmachado1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 51
전체 시간: 5,973
